Need Help Please CF30FWSAXAM
dalepbaker
#1 Post by dalepbaker »
Can Not get any drivers to fix PCI Acqisition and signal processing controller to work on Clean
install of Win 7 32bit
CF-30FWSAXAM
Model Number:
CF-30FWSAXAM Status:
DISCONTINUED MSRP:
$4,499
Description: WinXP (Vista COA), Intel Core 2 Duo L7500 1.60GHz (Centrino), 13.3" XGA Touch, 80GB, 1GB, Intel 802.11a/b/g, TPM1.2, Bluetooth, Wireless Ready, Rubber Backlit Keyboard, No Drive
I have removed the Bluetooth and Qualcomm cards.
Have tried many chipset,sd card and intel management drivers.If you have know good to work driver,you can send as attachment
to dalepbaker@comcast.net
or a liknk is okay too
Thanks Very Much in Advance
Re: Need Help Please CF30FWSAXAM
ETM driver is what you need..
Try the one for Mk2 vista. Or Mk3 win7, but you will have to unzip it manually and then install it.
Reading material
https://www.google.com/search?num=20&sa ... s5Qv9gvCZ0
More reading
http://forum.notebookreview.com/panason ... 30mk2.html
dalepbaker
#3 Post by dalepbaker »
dalepbaker wrote:Can Not get any drivers to fix PCI Acqisition and signal processing controller to work on Clean
CF-30FWSAXAM
Model Number:
DISCONTINUED MSRP:
$4,499
I deleted everything and did a Full Clean Install Windows 7 Pro Bit ,8Gb DDR2 ram,got all drivers working just fine,going to add 512mb SSD to really make it fast.
I did 2 this way
CF-30FWSAXAM full64bit ,ram is recognized in BIOS and Win 7 64bit of course
CF-30KWPAQAM did the same thing to it also.
Down side is ,only took 13 days to get everything working
So I gues this thread can be closed.
Thanks for all the hints and help.
Vista does NOT work
Rob,your suggestions got me thinking in a different way,thanks
A great Forum too.
Dale
Tactmedic
#4 Post by Tactmedic »
So you got 8 gigs of Ram to work? I was thinking of this for my MK3 which is still in the mail. Which Ram did you use?
CF-C2AKFZGLM My newest one :)
#5 Post by toughasnails »
Tactmedic wrote:So you got 8 gigs of Ram to work? I was thinking of this for my MK3 which is still in the mail. Which Ram did you use?
Just stick to the name brand and you should be ok.
Tactmedic
#6 Post by Tactmedic »
Yes, your right- after my issue with the Ram I bought on Amazon :damnit:
dalepbaker
#7 Post by dalepbaker »
ABSOLUTELY, DDR2
