It is currently Tue Jan 22, 2019 7:11 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 3 Next
 Post subject: gps in my cf-30
PostPosted: Mon Jun 16, 2014 11:28 am
hello
i have my first toughbook cf-30 it did not have gps so i bought one on ebay. is there any tutorial on how to do this and software i would need.
thanks pat
 Post subject: Re: gps in my cf-30
PostPosted: Mon Jun 16, 2014 11:52 am
Welcome to Toughbook Talk
Could you post your full model number and a link to the GPS that you bought.
Cel Google Pixel XL
PostPosted: Mon Jun 16, 2014 4:08 pm
cf-30CCQ92BM
http://www.ebay.com/itm/130754754096?ss ... 1423.l2649
PostPosted: Mon Jun 16, 2014 7:19 pm
these results will get you started..
https://www.google.com/search?num=20&sa ... umY9yWC0TQ
PostPosted: Tue Jun 17, 2014 3:42 pm
It's fairly easy..
REMOVE BATTERY AND DISCONNECT AC ADAPTER
remove strip above keyboard..slide keyboard towards lcd
.lift the keyboard..hope it isn't glued down, but usually they are.
Remove the stainless cover..directly under it is the bluetooth gps bracket..
Remove the 2 rubber pieces on the lid..attach the antenna and feed the cable down.
remove the hinge cover and stainless cover....feed the antenna through to the gps board.
attach the gps to the bracket and install the ffc cable..making sure of the correct side up.
reassemble
Thanks to Tango tough for the photos.
http://forum.notebookreview.com/panason ... -unit.html
PostPosted: Tue Jun 17, 2014 4:41 pm
https://plus.google.com/photos/10517987 ... 8304476254
this is what i was going by as for how to install it. it says at end to plug antenna into card at back and that you have to take bottom off. i am glad i looked for better info.
thanks shawn
PostPosted: Wed Jun 18, 2014 4:07 pm
pvballard wrote:
https://plus.google.com/photos/105179878228304476254/albums/5969277188573069761/5969277185964974770?banner=pwa&pid=5969277185964974770&oid=105179878228304476254
thanks shawn
LOL! This is my old employer!
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Wed Jun 18, 2014 5:24 pm
ok that was not as bad as i thought have it in no screws left over and it turns on. i started and hit f2 and saw that model no. here is cf-CTQAZBM not the same as on sticker on the back. so i am guessing this thing as been pieced together. i set the gps to auto and now i have a com 3 but Google earth does not see com 3 should i download another program to work with this.
thanks pat
PostPosted: Wed Jun 18, 2014 6:04 pm
Software to verify that the gps communicates is Winfast Navigator.
Many different opinions on other software.
For boating ask Cap on NBR...Is he on here? He is the authority on that..
For biking,hiking etc...I have no clue...
For Linux OS ask Sadlmkr...
For streets and driving many people use Microsoft.. Streets and Trips
Personnally I hate Micro.. Streets&Trips....I use a discontinued program from Garmin.. MobilePC..It accepts updated maps and works the same as the handheld Garmins...
PostPosted: Wed Jun 18, 2014 6:41 pm
streets and trips was to much money i use google earth to plot out installs to our towers i work for a isp. line of sight system.
