CF-30K (Mk3) and W7-64 Question
All,
I placed the below post on the notebookreview forum yesterday afternoon, under an existing topic that was opened duscussing this; and you guessed it, no follow replies yet :-(((((.
I figured I would put it on this site as well, especially being that it is time specific/sensitive and you guys are the best thing since sliced bread :
"Guys
Thanks for all the info.
I am going to try and tackle loading a TB30 Mk3(k) with W7-64 this weekend.
Couple of questions:
-Is 4 gigs of RAM the max that the mobo will support?
-Which drivers should be used? Pannys official driver site only has up to W7-32 drivers available to download for the Mk3.
Not sure if I would be better off with W7-32 or 64 though; I am mainly leaning toward the 64 bit since I have a copy of 64 ultimate/enterprise but only professional in the 32 bit flavor.
Thanks in advance for all your help gentlemen, it is very much appreciated.
Looking forward to your thoughts and words of wisdom b4 diving into this one
Have a great evening."
Have a safe and blessed evening
Sincerely and Respectfully,
Nick
the collection continue to grow.....where is stops only my wife knows and will tell me....LOL
"Guys
Nick
-31Mk3, 16gb RAM, Samsung 850 Pro 512gb, W10-64 Pro, Emissive backlit KB
-54Mk2, 16gb RAM, Samsung 870 EVO 1TB, W10-64 Pro, Emissive backlit KB
Re: CF-30K (Mk3) and W7-64 Question
Vista 64 bit drivers are an option I would think,I honestly would try 32 bit drivers and then list what refuses to work,even in compatibility mode.
I have a CF-52G that runs 64bit and I just used 32 bit drivers. I think everything was OK,and I just ran that drive in a 52GUN so I know the touch worked.
Just an alternative idea....
You can get an original win7 32bit restore disk for about $35. Pop it in and 20 minutes later and the CF30 mk3 will be ready to use..
What's the full model number?
Did it come with win7 32 bit originally?
If it came with win7 originally the restore disk will reinstall it perfectly. No need to even type in the COA number.
Win7 32 bit and 64 bit will both run on 4gb of ram. They will perform almost exactly the same with 4gb memory.
A cf30 will run with 8gb of ram installed.....It needs to be a certain type of memory.
With 8gb win7 64 bit will perform better. 8gb will cost around $100.00..
Shawn and safn1949,
Thank you both for your time and replies; it is very much appreciated.
@safn1949
I have downloaded all the TB30Mk3 Win7-32 drivers from the Panny driver site.
Guess I will see what happens on Saturday. Heck the worst thing I can image would be that, if all else fails, I will start over and install the 32 bit version
@Shawn.
The complete part number of the TB30 MK3 I will be working on this weekend is:
What's the full model number? CF-30KTPEQAM
-The TB configuration website shows...
-This unit originally came with 2gig of RAM that was upgraded to 4 gig by someone.
Shipped from Panny it was: Win Vista COA (YUCK) w/ Win XP downgrade option
-No sir
If it came with win7 originally the restore disk will reinstall it perfectly. No need to even type in the COA number. :-(((((
-Unfortunately, No restore disk came with the Mk3 beast, which would have be Win Vista (YUCK)
-Won't 64 bit allow all 4 gig be usable, since 32 bit shows only about 3.25 gig are usable?
-GREAT to know, thanks. Would you please sent me the specific RAM (Manufacture and Part Number), if you have it, that would be required to bump this awesome Mk3 machine up to 8 gigs?
-Would you happen to know if the RAM needed to bump up to 8gigs would be available for purchase from any of the wonderful and knowledgeable TB experts in this forum or would newegg be he best bet?
I will update this post with my findings and results after attempting to install W7-64 this weekend.
Thank you both once again for you time and assistance.
Please have a wonerful, relaxing, safe and blessed evening.
Sincerely and respectfully,
Nick
@safn1949
@Shawn.
-No sir
Nick
Cap said it best on NBR.....
"Although it's possible to conceive of some home uses for Ultimate, the features that separate it from Windows 7 Pro set it in a class that's almost exclusively for intensive international or network use. For most office or home power users, it's not really recommended."
CAP
memory info is here.
http://forum.notebookreview.com/panason ... -30-a.html
restore disks are available...post a request on this site..
A Win7 restore disk may work on your machine.....probably have to type in a serial number though....someone will know.
Guys,
Update on the W7-64 install on the 30Mk3....
I used all the W7-32 drivers that I downloaded from the official Panny site.
All hot keys worked, except that when screen brightness was reduced using Function + F1, it would stay at the reduced brightness intil the cursor was moved then it when back to 100% :-(((((((
Additionally, was unable to get the tscreen to calibrate correctly.
A bunch of driver was that the machine did not support them.
After hours 2 and 3 of yanking my hair out, I decided it was time to start over and load W7-32.
W7-32 was the trick, all drivers installed correctly and the Mk3 is now in service in traffic signal maintenance industry for one of my guys ....woohoo.
If any one has successfully loaded W7-64 on a Mk3 and it is working correctly; please let me know what and how you were able to accomplish it.
I would like to take the next Mk3 up to 8gb of RAM, using the info/type of RAM that SHAWN listed, and go W7-64 bit on it.
Once again thank you for help thus far and for any future ideas/direction/wisdom you fine group of experts are willing to share.
Thank you for your time and have a great evening
Nick
Nick
Yeah, but he has a Mk3, they are made to go to 8GB. But, it looks like you guys got him straightened away!Shawn wrote:memory info is here.
This Mk3 was originally shipped with MS Vista (YUCK), do they offer a restore disk for a 30Mk3 for W7-64?
The Part number for this machine is:
CF-30KTPEQAM
If so, would you please let me know so I can put a post of the B/S/T forum.
The S/N would be no problem what so ever.
I will be installing VM Ware workstation and plan on running more than one OS at a time once upgraded to 8gb, thus the need for W7-64.
Thank you all so very much for your time and assistance.
This an awesome forum and fortunate enough to be part of it.
Have a wonderful, safe, and blessed evening all.
Respectfully,
Nick
CF-30KTPEQAM
Respectfully,
Nick
restore disk will be 32bit as far as I know..
