Azrial's Keyboard Decal/Label for the CF-29
Azrial
#1 Post by Azrial »
Correct Panasonic’s Mistake!
If you upgrade your keyboard to an Emissive Keyboard you will most likely lose your hot key markings. Even if you get one of the rare emissive keyboards that have these markings or even a standard keyboard, they are quite small and hard to see in low-light.
I have the perfect solution, a keyboard label printed on high quality, high contrast, weather resistant material. These labels are original artwork and should be intrinsically understandable by anyone familiar with the hot key functions of the CF-29. They should be stuck to the bezel directly above the top keys. I have also included a GPS marked key for those that have this function or may add it. Using the shortcut command native to Windows use this previously undefined key to start your favorite GPS mapping software quickly with just one button.
Frankly, I think that these labels look pretty cool and I’m happy with the way they came out! You can't make two labels for cheaper, using the quality special materials I have, for less money!
Labels are only $2.90 (USD) each mailed CONUS for the first label and $2.00 each for all other labels. Sorry, but if you remove your keyboard the screws will damage your label, but at this cheap price, order two. Vendors, orders over 10 labels receive a special discount! Inquire about overseas mailing cost.
I mail within 3 business days of receiving your funds, usually much sooner, and will take Pal-Pal. Thanks!
Re: Azrial's Keyboard Decal/Label for the CF-29
#2 Post by Rob »
BRAVO to you! This is great! I'm making this one a sticky!
Azrial
#3 Post by Azrial »
Thanks Rob! :D
M3 Euro LTW
#4 Post by M3 Euro LTW »
Since you're not making these any more....
I wonder if you'd consider using this thread as a "sign-up", and if eventually enough people signed up, you would know that it was "worth" doing another run?
At the affordable prices you set, I bet people would even PrePay and gamble the numbers eventually got to the point you'd make another run. Just guessing.
Alex.
#5 Post by toughasnails »
and I bet you will be the first on the list :D
Azrial
#6 Post by Azrial »
M3 Euro LTW wrote:Since you're not making these any more....
Alex.
Hey Alex, Folks are welcome to sign up, if enough folks did so I would make some more. It was really part of a game/goal I set for myself to make my Toughbook "hobby" pay for itself! This is why I do not wish to go in the hole since I have zeroed out my costs to returns!
Now if someone wanted to buy my kit, which is the original artwork, reasonable tech support and sources, I would be happy to pass the mantel to the next fellow. My price now is a rock bottom, $50!
PM if interested!
ares93
#7 Post by ares93 »
Sign me up for one. Too bad i did notice this sooner. Then again, i didnt have a 29 in 2010...
CF-29LTQGZBM, MK4, 1526mb, KingSpec 64GB SSD, DVD, GPS, Emissive, XP SP3
#8 Post by toughasnails »
ares93 wrote:Sign me up for one. Too bad i did notice this sooner. Then again, i didnt have a 29 in 2010...
Well I just might have one or two kicking around if you want one . What I paid + 1 stamp for usa and 2 for overseas shipping :)
ares93
#9 Post by ares93 »
toughasnails wrote:Well I just might have one or two kicking around if you want one . What I paid + 1 stamp for usa and 2 for overseas shipping :)
Alrighty, I can go for that. Turns out the kb i bought from Rob had the logos, but me mate needs one anyway.
