CF-19 GPS Module
Banshee
CF-19 GPS Module
#1 Post by Banshee »
I'm after a dedicated GPS module that goes underneath the 3G and Bluetooth Modules for a CF19 Mk3 posted to the United Kingdom, what you guys got?
WittgensteinSergeant
Re: CF-19 GPS Module
#2 Post by WittgensteinSergeant »
Here's one, but it can be had cheaper I guess: http://www.ebay.nl/itm/Original-Panason ... 1459825859
Banshee
#3 Post by Banshee »
WittgensteinSergeant wrote:Here's one, but it can be had cheaper I guess: http://www.ebay.nl/itm/Original-Panason ... 1459825859
Thanks for the link mate, I've already got the antennae and cover, just literally need the card and was wondering if anyone on here had one at forum rates to help a fellow toughbook owner out just as I have for you ;)
Banshee
#4 Post by Banshee »
I swear this place is dead recently :(
#5 Post by Shawn »
Na.....You are in the UK, and many guys won't ship international..
If you can wait a few days maybe a week, I can setup a Ublox GPS module for you.
You would need to get the 12 pin ffc cable, but they are easy to find.
I have several things going on at the moment. I need to clear my plate some before I start a new project.
Banshee
#6 Post by Banshee »
Shawn wrote:Na.....You are in the UK, and many guys won't ship international..
Shawn that sounds great to me and will be much appreciated :)
What is the difference between a Ublox one and the standard one that comes in the Mk4?
Also can you link me to the FFC cable that I'll need? I presume that this will be the antenna for the card?
#7 Post by Shawn »
Ublox performs much better..Ublox is 50 channel and the stock one is 12 channel..
Don't worry about the ffc cable, I found an extra....
Send me a PM sometime and we'll work out the details....I assembled the unit and tested it today..
