It is currently Mon Apr 22, 2019 2:32 pm
PostPosted: Sat Jun 11, 2011 11:17 pm
I have been looking at a couple of 74's and was wondering if the cpu can be upgraded to the core 2 duo. Anybody know for sure ??
Cel Google Pixel XL
PostPosted: Tue Jun 14, 2011 9:30 am
NO SIR! It is soldered on!
I just checked on a busted mobo cf-74 I have laying around.
http://www.toughwiki.com
PostPosted: Wed Jun 15, 2011 2:47 pm
Too bad, just picked up a cf-74CCB unit I believe an earlier model with T2400 cpu I was hoping would be upgradable as the core duo cf-51's were. At least it's a sata hdd and upgradable to 4GB ram. Any one know how to finetune the touchscreen on these? Doesn't have the icon to hit on to do recalibrate on. Must check into control panel, thanks, Driller
PostPosted: Wed Jun 15, 2011 3:16 pm
Should be an option in the programs under the start menu... Fujitsu Touchscreen Calibration.
PostPosted: Wed Jun 15, 2011 3:32 pm
Let me know how the 74 works and how the screen is compared to the 51.
Cel Google Pixel XL
PostPosted: Thu Jun 16, 2011 9:46 am
mine is a Mk1 and I believe it has a non panasonic OS as I can't find anything for touchscreen calibration anywhere. The TS works but is just a bit off. Am looking for a restore disc for the cf-74 now and believe one on fleabay that I'll get and upgrade the ram and hdd to a sata maybe 500gb. opened up the top from keyboard and it doesn't gain access to MB that way. Must have to go from bottom. That makes me think as Rob said the cpu is NOT upgradeable, pooh! but anyhow, don't think it's as tough as fully tough but is a bit faster. If I can get new hdd and get panny version OS and calibrated TS it looks like a nice unit. Not cpu upgradeable is sad though. will let you know.......Driller
PostPosted: Thu Jun 16, 2011 10:04 am
Not unless you have the right machine/tool to unsolder 400+ pins and re-solder them... :sucks:
PostPosted: Sun Aug 28, 2011 11:26 am
TOUCHSCREEN CALIBRATION WITH UBUNTU 10.10 or 11.04
I have not rc'vd my restore disk yet. I did however load a custom copy of Ubuntu 11.04. For my purposes I set [Login Screen Settings] to [Ubuntu Classic (No Effects)].
Used calibration utility found here.
http://www.freedesktop.org/wiki/Softwar ... calibrator
CLICK WHERE IT SAYS DEBIAN TESTING (MENTORS) and load as directed.
Calibration is then found in [System][Administration]Calibrate Touchscreen
Save the snippet with:
Code:
sudo gedit /usr/share/X11/xorg.conf.d/99-calibration.conf
IOW NOT /etc/X11/xorg.conf.d etc. This yields an error message. See below image if this yields a huh? on your account.:D
Cut and paste this part to the empty file using your numbers.
Quote:
Section "InputClass"
Identifier "calibration"
MatchProduct "Fujitsu Takamisawa USB Touch Panel"
Option "Calibration" "1247 15615 1695 15403"
EndSection
The only other thing I change is to hide Firefox and use Chromium (from Ubuntu Software Center)
CF-74 CCBAXBM :)
1024 Ram 1.8GHz
Jeff :salute:
PostPosted: Sun Aug 28, 2011 1:53 pm
driller,
Do you have a file called brecal anyplace on that 74. Or maybe you could lift it from another unit. Then again since we are talking USB touch on the newer units maybe brecal won't work. Nope scrap that. You need \util2\drivers\tscreen\ftsetup.exe according to Pana Support............H-2008-0005.pdf (for cf-30 but there must be one for 74 somewhere)
FWIW
