It is currently Wed Feb 20, 2019 6:17 am
PostPosted: Thu Feb 11, 2010 9:14 am
Does anyone have the CORRECT/PROPER order in which the CF-73 drivers should be installed? I have installed all my drivers (more than once) and still cannot get the touchscreen to work. Device manager says it is installed and working properly and the calibration program will open, but nothing happens when I touch the screen. Touchscreen does not show in the BIOS. I have also checked the connections. Bad t/s?
PostPosted: Thu Feb 11, 2010 10:04 am
Bad touschscreen
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Thu Feb 11, 2010 9:10 pm
My CF-73S (Mk.4) has a USB-based touchscreen that does not show up in the BIOS even tho it works OK.
Not sure if that's true for other marks/models
PostPosted: Sat Apr 17, 2010 1:26 am
Yes. You have a bad touchscreen, you're going to need a new one.
