It is currently Sat Feb 16, 2019 4:00 am
PostPosted: Mon Feb 01, 2010 4:40 pm
I have a cf 73 that the touchscreen was working just fine. put it behind my seat in my pickup pulled it out later and touchscreen is there the problem is it stays along the left border of the screen no matter where i touch. in addition i cant figure out why there is a hid compliant mouse along with ps/2 in device manager. is there any fix for this or is the screen just messed up now
PostPosted: Mon Feb 01, 2010 4:43 pm
Go back into device manager and delete the hid compliant mouse. Should go back to normal and it is not an uncommon occurrence.
PostPosted: Mon Feb 01, 2010 4:50 pm
when i reboot the hid comes back how do i get rid of it for good and my touchscreen goes completely away without the hid compliant mouse
PostPosted: Mon Feb 01, 2010 4:58 pm
sorry i just realized i posted this in the wrong forum can someone move it to 73 forum
PostPosted: Mon Feb 01, 2010 5:06 pm
Moved... I was wondering why this was in the CF-29 forum lol
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Mon Feb 01, 2010 5:19 pm
my touchscreen wont work without the HID compliant mouse and the fujitsu mouse pad (usb) driver enabled. but the touchscreen mouse stays to the far left border of the screen
PostPosted: Mon Feb 01, 2010 5:23 pm
You say it just stays to the left, it does not jump around?
PostPosted: Mon Feb 01, 2010 5:30 pm
yep it will move up and all along the left side of the screen if i touch it in the middle the mouse will move to the middle just stays on the left wall if i touch the screen up top the cursor will move up to the left corner its like the screen/cursor is limited to a very narrow section on the left side of screen
PostPosted: Mon Feb 01, 2010 5:35 pm
Have you checked for debris under the left side? Sounds like it could be the infamous "crap under the edge". One of the Jedi masters should chime in here anytime, let's see what they say.
PostPosted: Sat Apr 17, 2010 1:28 am
This is the simptom of a bad touchscreen. You're going to need to replace it.
