It is currently Tue Feb 19, 2019 9:34 am
 Post subject: Calibration Tool
PostPosted: Fri Dec 25, 2009 5:16 pm
I installed my touchscreen driver and it works However, the screen needs calibrating. No icons show up in the system tray as usual. And one final note, when I try to open the calibration tool, error message reads Cant open driver, its like the file is corrupt however I cant load another one Can anybody help
 Post subject: Re: Calibration Tool
PostPosted: Sat Dec 26, 2009 10:45 am
TW, check my reply in the other forum under the CF-73 cali thread. I also told TC to delete your comment in the CF-18 thread as it is a double post. The Mods get angry when you start asking the same question in two or more threads as it makes it difficult to follow any comments on how to remedy a problem if it is spread out among several threads.
