CF-52 Internal WWAN - Where is it located?
Locked
#1 Post by Rob »
CF-52 Internal WWAN - Where is it located and can I simply take this card ($20): http://cgi.ebay.com/New-Sierra-Wireless ... e44501cand put it in?? or is a special sled needed on the CF-52?
I know that the CF-19 doesn't need a special sled... just pops in the bottom of the laptop into the express slot...
Anyone?? Anyone?? Alex??
P.S. the 52 we have is WWAN ready (CF-52GCMBXAM)
tomcat57
Re: CF-52 Internal WWAN - Where is it located?
#2 Post by tomcat57 »
I will look later ,as I remember there is 2 pci-e slots , one for the wi-fi and one for the wwan
Under the hinge cover is one place, could you look on the bottom area for a cover, thats where my cf-19's is
Alex
#3 Post by Rob »
Alex, for sure you are right... it is under the top button panel now that I'm thinking about it... Please confirm!
#4 Post by Rob »
I just ordered the $22 one. :)
tomcat57
#5 Post by tomcat57 »
What do you mean by confirm
I don't have one here to check for sure
Alex
#6 Post by Rob »
Never mind, I thought you had a CF-52. I know for sure that it is in the upper left corner under the button panel.
Thanks, thread locked
Locked
