cf-k52dm002
d9e5v4
cf-k52dm002
#1 Post by d9e5v4 »
Anyone know where I can get part number cf-k52dm002 ? Other than heartland. It is a dvd multi drive for cf-52. It is the sata version used in the newer ones.
Re: cf-k52dm002
I MAY HAVE ONE..I WILL NEED TO CHECK.. sorry about caps.
What is the full model number of your cf52?
Bill_TN
Re: cf-k52dm002
#3 Post by Bill_TN »
Hey Shawn? Won't this work as well? CF-K52DM001
Re: cf-k52dm002
#4 Post by Shawn »
The early ones are ide they wont work with later models...
d9e5v4
Re: cf-k52dm002
#5 Post by d9e5v4 »
cf-52vaaby1m. Yea the 001 is ide, 002 is sata.
Re: cf-k52dm002
#6 Post by Shawn »
Did you try an early model IDE drive yet?
Model Number:..CF-52VAABY1M
Status:..CURRENT LIMITED AVAIL
MSRP:..$2,979
Description: Windows 7 Professional, Intel Core i5‑3360M 2.80GHz, 15.4" WUXGA LCD, 500GB Shock‑mounted HDD (7200rpm), 4GB, ATI Discrete Graphics, Wi‑Fi, Bluetooth, DVD Super MULTI Drive, TPM 1.2, Toughbook Preferred
d9e5v4
Re: cf-k52dm002
#7 Post by d9e5v4 »
Yes, they don't work.
Re: cf-k52dm002
#8 Post by Shawn »
Ok, I will check although it may take a day or so...I have a lot of other stuff going on this weekend.
Swap meet...The truck needs new wheels.
d9e5v4
Re: cf-k52dm002
#9 Post by d9e5v4 »
Alright, thanks.
d9e5v4
Re: cf-k52dm002
#10 Post by d9e5v4 »
What all models have the sata dvd? I'm thinking about getting a cheap donor off ebay. It's way cheaper than heartland. Thanks
