It is currently Mon Jan 21, 2019 8:18 am
Post new topic  Reply to topic  [ 14 posts ]  Go to page 1 2 Next
 Post subject: DVD-Multi problem
PostPosted: Sat Feb 14, 2015 4:09 pm
What would cause the dvd-multi drive not to work. I Have a cf-52vaaby1m and the drive has never worked. It doesn't even open. I have put this drive into another cf-52 and it works great, and when I put another drive into this pc it doesn't work either. So it's not the drive itself. Nor is it a driver issue. What else could it be?
 Post subject: Re: DVD-Multi problem
PostPosted: Sat Feb 14, 2015 4:22 pm
One possibility is the cable from the dvd port to the motherboard is bad or unplugged.
Second posibility is the dvd is disabled in the bios.
third possibility is a blown fuse on the motherboard
fourth possibility is that is has a special bios that has the dvd permanently disabled.
Model Number: CF-52VAABY1M
Status: CURRENT
MSRP: $2,979
Description: Windows 7 Professional, Intel Core i5‑3360M 2.80GHz, 15.4" WUXGA LCD, 500GB Shock‑mounted HDD (7200rpm), 4GB, ATI Discrete Graphics, Wi‑Fi, Bluetooth, DVD Super MULTI Drive, TPM 1.2, Toughbook Preferred
PostPosted: Sun Feb 15, 2015 6:16 pm
Thanks for the reply, i'll start looking into it.
PostPosted: Sun Feb 15, 2015 6:40 pm
I have a 52P with the same thing going on,let me know what you find.
PostPosted: Sun Feb 15, 2015 7:04 pm
Check on the bios. Maybe your optical drive setting is Disable.
PostPosted: Thu May 07, 2015 12:11 am
It's nothing in the bios that I can find. I haven't had to time/courage to rip into it yet. I'll post my findings once I do.
PostPosted: Thu May 07, 2015 4:13 am
Please post a photo of the rear of the drive and post the exact model number of the drive.
What is the model of the CF52 that the drive works in?
PostPosted: Thu May 07, 2015 12:14 pm
I don't remember the exact model number but it was an older c2d p8600 cf-52 that I happen to have at the time. Both worked in the older one but neither in my current. So it's definitely my pc. One day, hopefully real soon, im going to take it apart and check it out.
PostPosted: Thu May 07, 2015 1:59 pm
You don't need to tear it apart....
The newer CF52 will only accept a SATA DVD drive....
The older CF52's use a PATA ..DVD drive....
The drive in the photo is a PATA....
It will plug in but will not work....
My CF52P must have a SATA drive, but oddly enough my CF52M will accept either PATA or SATA...
My CF52G needs a PATA only.. A SATA won't even fit the whole way.
PostPosted: Thu May 07, 2015 4:16 pm
Well that's awesome news. Thanks. I had no clue there was a difference. Anyone happen to have a part number for the sata dvd multi drive?
