CF53 woes
Re: CF53 woes
#31 Post by Shawn »
A couple more photos. I disassembled it a bit more..
safn1949
Re: CF53 woes
#32 Post by safn1949 »
Did you get the LCD?
Re: CF53 woes
#33 Post by Shawn »
yes I did ...thank you......Was the replacement the same brand? Did the replacement come with a touchscreen?
safn1949
Re: CF53 woes
#34 Post by safn1949 »
No,the replacement was for a CF-53 non touch,what you see there is all I replaced on it. I put the touch panel back but as I said it worked but no calibrate. I'll be honest and say I was afraid I would mess it up if I took it apart again. So I sold it as is and the guy is happy as he can get.I now have the tape needed to do the job right,sookwang hobby tape. Serious stuff. :D
safn1949
Re: CF53 woes
#35 Post by safn1949 »
Bought a CF-53 non touch tonight with 2 big lines running down the middle of the LCD,$350 complete. I was also going to mention to you I have the led back light from a CF-52mk3 if you think it will help you out.
Re: CF53 woes
#36 Post by Shawn »
Hmmmm...I'd like to convert my daily driver CF52G to LED......
Lemme think on it for a while..
thanks
