CF53 woes
Re: CF53 woes
#21 Post by Shawn »
Want to send that to me?
If so PM shipping costs..etc
safn1949
Re: CF53 woes
#22 Post by safn1949 »
Sure,I had a hard drive crash so email me your address again. safn1949@gmail.com. Don't worry about postage.
Re: CF53 woes
#23 Post by teo »
The inverter on that LCD is integrated as you will notice. You can also check its surface mount fuse for the inverter.
Sorry, man! I'm still in PI but I will be in BC soon.
Re: CF53 woes
#24 Post by Shawn »
photos....
No Teo.....This model has a separate inverter...see photos..
safn1949
Re: CF53 woes
#25 Post by safn1949 »
Exactly the same as the one I had,what a SOB to get apart until I got a small knife in between the layers.
Re: CF53 woes
#26 Post by Shawn »
I spent a few minutes on this as dinner was cooking.
I rang out the wires in the video cable that are for the backlighting..They checked out ok, at least the ones for the backlight..
Could not see any fuses on the inverter / touchscreen PCB.
The fuse beside the video connector on the motherboard checked ok also.
I want to attempt to light the LED strip with a battery ...
Re: CF53 woes
#27 Post by Shawn »
Well here is my idea..
It does have a picture on the screen...Just zero backlight.
I agree with Teo that the original wire can not handle the current.
If I just replace the cable or whatever failed, the problem will eventually return.
The Touchscreen and non touchscreen seem to have different cables and lcd panels.
I don't really care about touchscreen. Using a non touch screen or disabling the touchscreen will remove that current draw on the tiny video circuit that fails.
safn1949
Re: CF53 woes
#28 Post by safn1949 »
Sounds like a plan, I just cut the panels apart and replaced the inner one shown in the photo as it was broken. I tried to put it together minus touch panel but unlike the 52 there is nothing to hold it in as its glued to the bezel.
At the time I didn't have any tape thin and strong enough to do that.
Re: CF53 woes
#29 Post by Shawn »
I have a fantastic assortment of tape...
Re: CF53 woes
#30 Post by Shawn »
I do have 12v to power the backlight at the panel..
I do not have 3v at the backlight enable pin..
I think the voltage is low on the PWM pin also.
