CF53 Webcam / Microphone
#1 Post by Shawn »
Anyone have a part number or wiring info?
Would like to add this option...CF53J....
RDTyler
Re: CF53 Webcam / Microphone
#2 Post by RDTyler »
http://www.ebay.com/itm/291441023075?ss ... 1555.l2649
All the part Numbers are in this listing
These are from a mk1 pull
Although I did install it in a mk3 touchscreen cf-53s
The camera was working in the mk1 and the mk3
The only issue i had was in windows 8 the touchscreen input functionality disappeared - obviously a driver issue and older hardware - but lcd worked camera worked and touch was working in a factory install of win 7 on the mk3.
So I would believe this would work fine with a mk2 since mk2 is a closer to the internal hard ware of a mk1
On a side note: *(alot of toughbook parts are backwards compatible or actually used in the next mk) - (example: cf-19 mk3 bluetooth card will work in a mk2, and a cf-19 mk1 wifi card will work in a mk2 but not a mk3)
Hope that helps any questions just ask
