It is currently Sat Feb 16, 2019 4:02 am
 Post subject: AC Power Supplies
PostPosted: Thu Jul 19, 2012 1:49 pm
Can I use a CF 25 power supply for a CF 27?
I'd have to change the plug. The CF 27 came with an 110 power supply that has 16V output. I have a CF v25 powersupply that indicates it puts out 15V.
 Post subject: Re: AC Power Supplies
PostPosted: Fri Jul 20, 2012 12:09 am
Yep it should work although the CF-27 will charge slowly if it's running because the CF-25 supply produces less current. Keep an eye on the CF-25 supply -- it's 12 or more years old and the insides may have fossilized.
