It is currently Tue Feb 19, 2019 11:52 am
Post new topic  Reply to topic  [ 14 posts ]  Go to page 1 2 Next
PostPosted: Thu May 12, 2016 1:50 am
Somehow I managed to kill the non-BL/China chiclet keyboard of my 19 last night, it was next to me on a stool and I had dripping hands.
Most keys don't work anymore, so I can assume that it's pretty much dead?
PostPosted: Thu May 12, 2016 3:35 am
I'm not familar with this particular keyboard,
but it usually helps to let wet electronics airdry for a couple of hours.
PostPosted: Thu May 12, 2016 4:20 am
I ran Prime95 on Blend all night long and it didn't fix it, nor did a few minutes at 50C in our oven.
PostPosted: Thu May 12, 2016 4:34 am
The inside is a plastic sheet with contacts on it. Not really much to get permanently damaged by water. Let it air dry for a day or two.
Did you try a different keyboard? Does it work?
Here is a photo of the sheet inside a rubber keyboard. The emissive is very similar.
PostPosted: Thu May 12, 2016 6:10 am
I already ordered a new keyboard, but I didn't try another KB as I don't have one.
PostPosted: Thu May 12, 2016 10:51 am
Yeah it's completely dead, I soaked it in WD40 and it still doesn't work anymore.
Into the trash it goes then, gotta wait about 1.5 weeks for my new KB.
PostPosted: Thu May 12, 2016 5:10 pm
User32 wrote:
I soaked it in WD40
:eek:
PostPosted: Fri May 13, 2016 7:45 am
why the heck would you soak it in WD40? if you can disassemble it enough to get at its innards, using contact cleaner would be better than WD40...... which I wouldnt EVER use anywhere near a computer!
Panasonic Toughbook
CF-30KTPAX2M
Win7 Pro 32bit
160gb/4gb
Gobi2k WWAN&GPS
Intel 5300 WLAN
Sony Optiarc AD5540 Optical
More goodies to come
PostPosted: Fri May 13, 2016 1:24 pm
Hey, it worked for my dad's car which had a coolant leak over the BCM.
PostPosted: Fri May 13, 2016 7:52 pm
FYI
It is much much much better to use electronic cleaner spray. It dissipates water without leaving residue.
