swap list.
Bill_TN
swap list.
#1 Post by Bill_TN »
I thought I'd seen a parts swap list in here some where. But danged if I can find it now.
Re: swap list.
#2 Post by toughasnails »
No swap list but you can start one in the Buy Sell Trade thread here http://www.toughbooktalk.com/viewforum.php?f=16
Re: swap list.
#3 Post by Shawn »
Do you mean swap has in trade from you to me?
Or swap from CF29 to CF30?
Bill_TN
Re: swap list.
#4 Post by Bill_TN »
Uh no. I ment an interchange compatibility listing.
Re: swap list.
#5 Post by Shawn »
There are a couple of them. I will search.
here.
http://forum.notebookreview.com/threads ... ty.343439/
I read in an old post that a CF27 handle (with D rings for shoulder strap) will fit CF52
We all know keyboards swap from 27,28.29,30,31,52,53..........73,74 too I think
Lcd's swap from 29,30,73,74,52GUN..nits do vary some though
Doors, port covers and antenna covers from a 18 fit on a 19
Keyboard from a 18 works on a 19
I am pretty sure a bluetooth from a 30 are the same as a 19....the cables are different.
Battery from a 29 will work in a 30,51,52,53 not sure about a 31 but I think so...They re NOT backward compatible...
Re: swap list.
#6 Post by toughasnails »
I just made that thread a Sticky. There is a lot of great info there. It is still closed but will open it once I get it cleaned up. The thread got off track some.
Bill_TN
Re: swap list.
#7 Post by Bill_TN »
Cool. Hmmmnnn. I'm thinking...............
Re: swap list.
#8 Post by toughasnails »
Bill_TN wrote:Cool. Hmmmnnn. I'm thinking...............
That's not good Bill. Every time I start thinking it cost me $$$$$$$$
Re: swap list.
#9 Post by Shawn »
Glad that thread finally made it to a sticky.
Bill_TN
Re: swap list.
#10 Post by Bill_TN »
Well I have a few 51's and a few 29's with those rubber backlit key boards. They LOOK like they might cross to the 51's.............. At a glance they look swap-able.
