Anyone have problems swapping keyboards?
Tactmedic
#1 Post by Tactmedic »
I swapped a keyboard and now the 4 key doesn't work. I think I was careful as possible has anyone else had an issue like this?
CF-C2AKFZGLM My newest one :)
Re: Anyone have problems swapping keyboards?
#2 Post by Springfield »
Not a typical problem, usually more than 1 key fails if it's a cabling problem. Possible bad keyboard?
Tactmedic
#3 Post by Tactmedic »
Its working great except for that key... looks like i will be swapping them out again
#4 Post by SHEEPMAN! »
Does it feel right? Possible a crunchy under it.
Tactmedic
#5 Post by Tactmedic »
yes it felt different compared to the other keys, anyways I swapped in another keyboard
testing 4444444444$$$$$$$$$$$
YES! the other keyboard was cruddy anyways, must of been a slob who used it....
#6 Post by Shawn »
I vote for a Cheeto under the 4 key.
safn1949
#7 Post by safn1949 »
Yep,take the other board and hose it out. Then you will have an extra if you drop something big and heavy (coffee cup) on it......ask me how I know. :D
#8 Post by Shawn »
Let it dry for several days if you use water.....
I strongly suggest canned air.....
Tactmedic
#9 Post by Tactmedic »
hummmm, I just put it back on my parts machine... so take it off and clean it with H2O, and air pressure? Sounds like a plan...
#10 Post by SHEEPMAN! »
nah! Just hose it sideways with canned air. It's Tough. :D Sorry, Shawn...missed it ...Cheetos or Grandma's Oatmeal Cookies would be my guess.
I had several problems with the P key and others. Always it was crunchies. (if it was a single key that is)
