Itching for change... Thoughts?
Re: Itching for change... Thoughts?
#31 Post by ADOR »
I had modded the thermal pads on mine, so I didn't really see a big jump. The over clock is done though software and must be done every boot. This program works for windows, mac and linux.
http://www.gmabooster.com/home.htm
When you start it up it will show you what your clock speed is currently set at.
I don't remember what mine was set at from the factory on the CF-29 as I had it swap it at boot.
If you are wanting more performance download the latest correct driver for your chipset and then look up a modding tutorial or video. It will show you how to go in and change all the settings to where you want it.
Right now I am playing Portal 1 on medium to high setting on a CF-30 Mk2 with X3100 graphics. I have done a lot of tweaks to windows 7 but haven't even done the video tweak yet. Trying to get everything how I want it with some new tweaks I haven't done before to see how they work. Then it will be time to drop in the SSD.
(CF-30FCS80AM) Mk2 Intel 965 chipset, x3100 graphics. There seems to be a lot you can do with these graphics but you got to tweak it a little.
I use to play HALO 1 all the time on my CF-28 Mk2, it played well but some of the colors were off. I could never get the chief from grey to green. It was hell to play muli-player, lol.
Twocents
#32 Post by Twocents »
Thanks for the information :) I'll give that a try eventually, but right now time is at a premium and other things are taking precedence.
#33 Post by ADOR »
If you don't like it or your machine doesn't work well with it, you can uninstall it like it never happened. I try to softmod all my stuff like that for that reason.
I am still working with a experimental os, what I have seen in the virtual machine right now looks very good. When I get home from fire school in New Orleans I will be putting it on one of the CF-29's that I am selling to test it out on a older machine first. I am running it on a my CF-30, but have the virtual machine turned down to only use one core and 512 of ram and it screams in speed. Fill in more about it later.
Gear6
#34 Post by Gear6 »
I'm eagerly waiting for my new CF-19 mk4 (same model as Rob's) :D
I've already ordered 2x4GB Crucial PC10600.
while on that, I would want to know if all I need for wwan is the card itself, or i'll have to buy that board with the miniPCIe slot and dip switches, also.
C1mk1&2, CF19mk4, CF30mk1&mk3
#35 Post by ADOR »
That board comes with it. That is why they are considered "wwan ready".
#36 Post by Rob »
Gear6 wrote:I'm eagerly waiting for my new CF-19 mk4 (same model as Rob's) :D
And these models don't have the secret password that no one knows to unlock the WWAN! :)
Just use the GOBI unlock tool.
Where did you get yours from Gear6? :D :P :cheers:
Gear6
#37 Post by Gear6 »
Rob wrote: And these models don't have the secret password that no one knows to unlock the WWAN! :)
I thought so, but wasn't 100% sure about the wwan. Thanks for clearing that up.
The other good thing about the mk4 vs mk5, is that you can install a FPR and it would work (Alecgold knows this all too well).
Also I like the fact that it's 18W TDP vs 35W on the mk5, and that surely means lower heat, and probably better runtime, even though performance wise it's a different class.
Rob wrote: Where did you get yours from Gear6? :D :P :cheers:
well..., some guy in a suit made me on offer I couldn't refuse :D
cheers mate ! :cheers:
